Hey all,
So I've got my 1987 LeBaron TII conversion quite mechanically sound by now. However I still can't get it to run properly. I've employed the help of a very reputable independent mechanic and even he is having trouble with it.
What is happening is that the Logic Module is unable to get a signal from the temperature sensor. My mechanic thinks the problem is the wiring harness. My car has the harness out of a 1987 Daytona installed which has the correct 4-wire AIS sensor hookup and everything else needed for TII. My mechanic hooked up a code reader and the Logic Module said that the engine temperature was 197 degrees below zero!
Because of this the engine surges out of control at idle because it thinks that it is cold. Put it in neutral and it revs right up to 2100 RPM. Otherwise it is perfect. Good fueling and ignition. Also, since the temperature loop isn't working the engine won't turn on the cooling fan by itself. I just said 'to hell with it' and installed an after-market cooling fan thermostat which works quite well now that it is dialed in.
Can anybody think of a reason why my LM isn't getting a good temperature signal? It seems crazy that it would be the harness. Can I just get a new temperature sensor and run a new set of two wires all the way to the LM to make damn sure that the loop is good???
Thanks everyone.
Thanks everyone.
