Car:
86 Shelby charger. 100% rust free and straight. maybe 5 SMALL dings. the body is almost 100% sanded. Entire front clip is removed as well as the GFX. most of the interior is removed. The interior is perfect and i have all the peices to put it back minus the carpet.
MISC:
kyb struts/ shocks all the way around. poly bushings in the rear. new poly bushings for front and sway bar. Walboro 255 fuel pump. Spearco 1100 CFM FMIC. ZIENTRONIX Wide band kit ( LCD with TPS, A/F, Boost, EGT, ECT) New Battery, T2 overlay harness. 3" I/C pipeing ( exhaust for a chevy truck, has all the right bends) Comes with a set of crab wheels and a set of 16" pumpers. all wheels have decent tires on them.
BLOCK:
Professionaly assembled 89 2.5 converted to 2.2. forged crank.10 under. T2 rods. 40 over JE pistons. high volume oil pump. Tri-metal bearings.
Engine:
menagon head casting 287( full port/ polish +1 valves, heavy duty springs. everything in the head is brand new) Taft stage 2 cam with high RPM lifters. New water pump, A/C delete bracket, Magna core wires, new champion plugs, cap, rotor. TO4E turbo ( .63 housing with 53 trim stage 3 wheel) 2.5 " S.V. Stainless braided Turbo lines. Ported exhaust mani, Ported 2 piece intake, Accufab AFPR, +40 injectors, stock TB. Used PS pump ( needs installed) New power steering lines. 3" D.P. ,3" side exit Exhaust ( no cat no muffler) All new motor mounts( some Solid) New timing, alt,P.S. belt's,
Tranny:
stock A555, Ceramic 4 puck clutch, resurfaced stock Flywheel. P body shifter cables, 555 shifter.
The car still needs (off the top of my head) Cam caps and rockers, Drive Shafts, new brake rotors.
the P.S. pump needs installed as does the I/C, front clip ect. some wiring needs finished.
i have completely ran outta money. i have $11K in this build and i owe way to much money. its needs to leave and i need to buy a car that i can actually drive. Im selling the car as is with all parts i have for it. im also including all the primer needed to prep for paint. i will make the car roll so it can be loaded on a trailer. IM sure im forgeting more parts, as i remember them i will add them. I also have almost every reciept.....
I will take $6000 for the car and all parts i own for it. i will take no offers as im already losing my a$$ on it. i will not part it out either.
you can contact me at [email protected]. or 1-330-807-9254. but please only call if you are very serious about the car. here are two pics of its current condition.
MISC:
BLOCK:
Engine:
Tranny:
