1 - 2 of 2 Posts
Trying to locate the fan relay so I can hook up a switch but not having much luck, is it one of these? I was told to look for a dB/pk wire that triggers the relay on the ground side but none of these relays have a dB/pk wire.
Discussion Starter #2
Never mind pulled
some tape back and found where someone must have put a new end on and soldered the blue/pink into a white wire, switch is all wired up and working, this post can be deleted.
1 - 2 of 2 Posts
