Hello,
This is my first post on this forum. My friend Paul, known as Laurp, advised me to ask for help over here.
I bought a Chrysler LeBaron 3.0 V6 from 1992 this March via the LeBaron network in the Netherlands. Test driving it and doing a key dance gave no codes than 12 and 55 so there was no problem at that point. When I picked it up it started to give a Check Engine light after about 20 minutes driving with fault codes 17 and 32. At that point I thought these codes had to do with the gearbox: intern TCM failure for code 17 and hydraulic pressure for 32. I got it checked at a professional garage for gearboxes. The box is revised about three years ago. They could not detect the codes and nothing was wrong. The car drove fine. It did not stuck in gear two, for example.
The codes came and I did reset the board computer several times by disconnecting the battery. Recently the board computer was cleaned but unfortunately the codes stayed.
Yesterday, after 40 miles driving to my work, I heard a high zooming sound from the back. I did the 'key dance' and there was no code besides 12 and 55. I started thinking and recalled a broke fuel pump I had with the LeBaron I had before this one. It was about the same sound. When I drove back from my work I heard the sound again and this time, after a few minutes drive at 60 mph the car kind of blocked for a moment. I drove on and after 30 minutes, driving at 80 mph, it blocked again for a short moment. Luckily I returned home safely. There was no indication light Check Engine but the key dance gave codes 12, 17, 55.
At this point I have a few diagnosis:
Spark plugs were renewed recently but maybe one of them got broke?
Is the fuel pump almost dead? And/or does the fuel filter need to be replaced?
Is there something wrong with the gearbox if the fault codes do point at that?
The VIN code of my car is 1C3XJ453XMG162421.
I hope this message is clear enough to help me find a diagnosis.
Thank you very much in advance!
Clement.
Clement.
