whats to the right of the oil cap? Is that for the intercooler hose? I see your AC foam is cracked. Can you just tear it off? I'm guessing its there for a reason
To the right of the oil cap is the intercooler pipe...I didn't have the turbo-to-intercooler tubes ON in this picture sorry.Tudds said:whats to the right of the oil cap? Is that for the intercooler hose? I see your AC foam is cracked. Can you just tear it off? I'm guessing its there for a reason![]()
That picture is a night and day difference between the picture from when you bought the car. :thumb:Man this picture makes the engine look dirty...it's quite clean in person.
Man you're just FULL of kind words today...Tudds said:how do you recover it? Do they sell the foam? I hate that its all ruined. Any tips for someone on replacing vac lines? I have no idea what I'm doingDo you use zip ties or what? I was going to find the lines where I can find the ends to and put a new piece in for everything. You buy the vac tubing by the roll anyways
BTW, that paper filter looks kinda sad![]()
Why thank you! :thumb: The airbox assembly will soon be removed and put in storage in favor of some flexible silicone intake tubing for the turbo with a cone filter in the nose of the car. Ok Tudds?RJ138 said:That picture is a night and day difference between the picture from when you bought the car. :thumb:
I will soon be redoing the vac harness on my car. Did you get a vacuum distribution block? What did you keep hooked up?
Thanks,
Ryan
When I went to put gas in the the car 2 days ago I noticed that there was a ton of pressure in the tank...so I left that tube vented/open. :thumb:GLHNSLHT2 said:Looks Clean Chris, might want to leave the line back to the tank vented though.
