sounds like something is hitting the ring gear theets, does the sound only happen when you press down on the clutch pedal? if so it might be the backing plate rubbing on the flywheel
Vroom vroom.
No it happens more when I'm cruising at higher rpms if that helps?
Sound to me like the noises you hear when the inspection cover is hitting the flywheel/converter.
