I was told those are bulb powered, that you can remove the bulb and replace
the old unit, but does anybody have a part number?
How hard is it and what proceedure do you take to remove the units?
I seen one large bolt that hold the unit in place but is that all it takes or did I not see something?
Bearcat
Yes, they are removable. You can get the bulbs anywhere. Like $5.00 at Walmart. They are 55 watts. You could always put a 100 watt bulb in. I'm not sure if the thing would last though. It may overheat. They cost the same or possibly a very little more.
They are H3 bulbs. Here's a link to some pictures.
http://amoparx.net/bulb/
Discussion Starter · #4 ·
THANKS!
It appears I have to unbolt the lights from the mountings and then yank the bulbs.. not bad..
once more Thank you!
Bearcat
