1 - 9 of 9 Posts
Hi there! I'm new to this forum. I'm actually from Winnipeg, Manitoba, Canada. Thought I'd try and advertise my car on here. To make things a bit easier for myself I've decided to just copy and paste my ad. If interested, there are more pictures available.
Cheers!
Second owner! Never winter driven! Fully loaded! 2.5L, 4 cyl, 5 spd, turbo/intercooled. In 2004 the car was converted into a street race car. Approx. $12,500+ invested in pwrtrain, & other parts & accessories. Original motor and low kms! All mechanical work was professionally done. Receipts avail. Absolute immaculate shape inside & out! MUST SEE! Last quarter mile time run, [email protected] as of Sept 2004 (time slip avail.). There is absolutely nothing wrong with the car.
Serious buyers only please. $9,000-$10,000 CDN. Approx. $7700 USD.
**PRICE IS NEGOTIABLE**
Here is a list of some of the things that were done to the car:
- Super 60 T3/T4 Turbo
- Spearco 1100cfm flow intercooler
- Port-match, head, intake, exhaust
- Ported/Polished head
- Head Mod + 180 degree mod Thermostat
- MP Head Gasket
- OEM Underdrive pulley kit + belts
- Resurface flywheel
- Greddy Type R Blow off valve
- Manual dual stage boost
- Dual Solenoid + High/low pres switch
- +40% injectors
- 3 Bar map sensor
- High performance fuel filter
- Super 60 Fuel Pump
- Full 3” Dynomax exhaust/muffler system
- Aftermarket twin pillar pod mount
- Cyberdyne Fuel gauge
- 30lbs Autometer boost gauge
- MP custom computer – programmed 28lbs psi
- Custom cold air intake
- 800 CFM K&N Filter
- High performance Magnacore spark plug wires
- Champion high performance spark plugs, rotor , cap etc.
- R/T Clutch
- Balance shafts removal
- MP Water pump
- MP Rear E-brake shoes
- MP Shelby Front/Rear break pads
- MP Shelby Front/Rear Discs
- Eibach 1” lowering springs
- MP Shelby Front struts and rear shocks
- 18” Velox Performance rims
- Nankang NS-2 225/40HR18 tires
- Ungo 3-Button shock & motion sensor car alarm
- Professionally installed all around window tint
- Car stereo system (Panasonic cd player/controller, Boston Acoustic RC61 6.5inch component speakers w/tweeters, Alpine 12” Type E subwoofer, Alpine 200w 4-Channel V-Power amplifier)
How often can you find a Daytona like this one, hop in it, turn the key and drive. Keeping in mind you are driving very nice looking low 13sec car! Possible 12's with slicks/drag radials.....I really can't find anything that some one would want to do with it besides maybe building it up further so that it can run 10's, 11's! :thumb:
Discussion Starter #2
I see not one reply...........I will let it go for $8000.00 Negotiable.
The car alone without the build up is worth at least $6-7 grand.
**MUST SELL**
I will take offers.................
Is the car in Canada? I would do 6k if I could get up there and drive it home, but the borders are closed and my job won’t allow me to travel right now.
MUST SELL
Hello,
I'm looking for a 1990 or 91 Dodge Daytona. I use to have one, but it had trouble and had to junk it, but I love them.
Do the headlights go up and down?
Does the odometer work?
Does the ac work?
Is this a 5 sp or automatic?
Thank you.
Jeannie
Cheers!
PRICE IS NEGOTIABLE
  • Super 60 T3/T4 Turbo
  • Spearco 1100cfm flow intercooler
  • Port-match, head, intake, exhaust
  • Ported/Polished head
  • Head Mod + 180 degree mod Thermostat
  • MP Head Gasket
  • OEM Underdrive pulley kit + belts
  • Resurface flywheel
  • Greddy Type R Blow off valve
  • Manual dual stage boost
  • Dual Solenoid + High/low pres switch
  • +40% injectors
  • 3 Bar map sensor
  • High performance fuel filter
  • Super 60 Fuel Pump
  • Full 3” Dynomax exhaust/muffler system
  • Aftermarket twin pillar pod mount
  • Cyberdyne Fuel gauge
  • 30lbs Autometer boost gauge
  • MP custom computer – programmed 28lbs psi
  • Custom cold air intake
  • 800 CFM K&N Filter
  • High performance Magnacore spark plug wires
  • Champion high performance spark plugs, rotor , cap etc.
  • R/T Clutch
  • Balance shafts removal
  • MP Water pump
  • MP Rear E-brake shoes
  • MP Shelby Front/Rear break pads
  • MP Shelby Front/Rear Discs
  • Eibach 1” lowering springs
  • MP Shelby Front struts and rear shocks
  • 18” Velox Performance rims
  • Nankang NS-2 225/40HR18 tires
  • Ungo 3-Button shock & motion sensor car alarm
  • Professionally installed all around window tint
  • Car stereo system (Panasonic cd player/controller, Boston Acoustic RC61 6.5inch component speakers w/tweeters, Alpine 12” Type E subwoofer, Alpine 200w 4-Channel V-Power amplifier)
1 - 9 of 9 Posts
