1 - 9 of 9 Posts
I do not go back to 86 but the newer manuals I have say no.
Relieve fuel pressure,remove the vacuum line, the return line and the attaching nuts and off it comes.Lubricate the O'ring and reverse the procedure to install.
Actually if I recall correctly a TI is even easier, I think it is just connected by barbs, so you loosen the clamps and just pull the hoses off. I had to ghetto rig an FPR on for the time and the only was I had was a TII so I just clamped the hoses on to it as best I could:D Worked pretty good except for one time the hose came off while I was in a turn lane on a busy street. I had to get out and reconnect the hose which took all of 30 seconds.
pretty sure you do not ever have to remove the rail except on a TII 2 piece intake car possibly
This is one of the biggest problem's with our cars, they are actually easy to work on for the most part but getting the right parts seems to be a hassle.
1 - 9 of 9 Posts
