While I have it up on jackstands, where it will stay for a few days, I need some direction on why is causing a 'popping' noise-it seems to happen if I go up a small driveway 'ramp' and one wheel is higher than the other-when the lead wheel is at the crest of the incline and the trailing wheel is at the base and beginning to ascend, there is always a 'pop', either side can be in the lead-I generally go up and down in such a way so that I don't boog the front Air dam on my 88 daytona shelby z-I have checked ball joints, bushings, control arms and wheel bearings, they all seem to be tight-the wheels, when off the ground, and you push.pull, @ 3 o'clock/9 o'clock and 12/6 have no wobble at all. I checked the mounting bolts at the K frame and they are tight and there doesn't seem to be any flaws in the K frame itself that I can see-it does not seem to be related to motor mounts (usually just gently going into the driveway) so I don't know where I need to look closer. Any ideas at all appreciated-thanks
