It will work in a LeBaron but the stick is actually bent back about an inch farther than a stock Lebaron unit. This will just make all the gears and nuetral farther back than where it is now. I belive this one is bent toward the driver an inch as well(Jory can tell you for sure as I have made many that way) so it will be closer toward you. If nothing else and you get it from him I can make you a new stick the way you want it if you dont like this one:thumb:If you are sure it will fit a 92 a568 lebaron,I will take it for the $50 plus actual ground shipping- actually I can have fed ex ground pick it up at your house if you box it up and leave it out. Let me know
Winston
It will definitely work in a Lebaron. I know that Daytona shifters are straight and not bent like this one, but my buddy replicated this shifter for his 92 Daytona and the angle brings the shifter closer to you, it feels real nice and your hand drops right onto the shifter. So I'm positive this will work well in a Lebaron or Daytona. And yes it is angled toward the driver like Jackson said. This is a great shifter but I need $, so I gotta let a couple things go.If you are sure it will fit a 92 a568 lebaron,I will take it for the $50 plus actual ground shipping- actually I can have fed ex ground pick it up at your house if you box it up and leave it out. Let me know
Winston
sounds good thanks, let me know if you buy cores. :thumb:It will work in a LeBaron but the stick is actually bent back about an inch farther than a stock Lebaron unit. This will just make all the gears and nuetral farther back than where it is now. I belive this one is bent toward the driver an inch as well(Jory can tell you for sure as I have made many that way) so it will be closer toward you. If nothing else and you get it from him I can make you a new stick the way you want it if you dont like this one:thumb:
