The tank should be the same dimensions year to year. The big change from 90 to 91 was the fuel pump design. Rockauto shows the 91 tank not having the attached sump in the bottom, which could be related to the larger pump housing on the 91+ units.
Physical size looks same. Differences include:
Different style fuel pump new style has plastic reservoir as part of pump. Old style has baffled tank. Also connectors are different for pump.
New style uses quick disconnect but you can use existing hoses.
Finally, return line is incorporated in pump instead of sending unit but you can plug extra line.
Rest is same (2dr & 4dr):
Fuel filler tube & seal, rollover/vent & grommet, & straps.
If you need, I have a complete set-up for late model including the harness from a '91-up.
http://www.turbododge.com/forums/f7/f28/1241010-new-complete-fuel-tank-pump-assy.html
