221 - 230 of 230 Posts
Awesome! That should fly! What kind of clutch are you running? Also how did you shorten the srt4 axles? Did you have new shafts made?
Adam
Discussion Starter #223
Using a act 6 puck. Custom dss axels. Just went to the track and broke the drivers side axel unfortunelty before I could get the tune dialed in a little better
I heard that if you use the dual mass clutch set up that it holds less power than with a single mass, they dont say how much less though, cant believe people seem to break these dss axles pretty regularly, every single thread i can find about them they are breaking right out of the box basicly, wish we could find another solution for axles...
Well the fronts were easy..everything from the srt bolted right up besides the top strut tower bolts..we had to drill a third hole.
And as for the back i picked up the turbo daytona disc/5 lug setup for the rear
I figure its a long shot getting a reply on this but I'm basically basing my entire swap after this thread, is the a reason you couldn't use the srt4 setup for the rear? Just checking before I run into issues when I start here in a week or so.
The rear of a srt4 uses a different style of mounting the brake system and the rear swing arm on a horizon uses 4 bolt on the along with the Daytona so the rear brakes setup is a direct bolt on.
