1 - 8 of 8 Posts
Hi All ! In market for a Garret Turbo Wastegate Vacuum Can with adjustable
rod. Unit is from '93 Daytona Iroc-R/T,2.2 intercooled.
Anyone know if these units can be rebuilt ?
Thank You,'93-/R/T
:confused:
I have one left that one of the threaded posts out of the 2 broke at the nut. worked fine it broke when i took the actuator out of the bracket. would send it to you for 15$ shipped as i dont need it just offerning. i sold my last good one for 50$
Thank you for replies.
I just un ceased the rod.
Question. I noticed the rod moves outward from the can &
the spring(inside can)pulls the rod inward.With regard to the
the hose located on the can, this is not a vaccum hose but
but a pressure hose for boost,right,or am I wrong ?
Thanks,
Frank
vacuum through that hose holds the rod in and pressure outward actuates the rod out to release the wastegate and let off boost
1 - 8 of 8 Posts
