Gasket matching 782 Swirl head on the exhaust side?
402 Views 6 Replies 4 Participants Last post by  Tonatom
Is it worth gasket matching the head on the exhaust ports? I already ported and matched the exhaust manifold so I'd assume I might as well do this but the ports get tiny 1" inside the head anyhow.
I'm not in the huge gains crowd, but a quicker spool up never hurt anyone.
Is it worth it?
Was planning on getting a 2.5" swing valve and down pipe. But due to $ constraints for now might just stick with the 2.25" swingvalve and exhaust. Other than open the exhaust up to a true 2.5 where it necks down over the rear axle, into a new muffler.
Thanks for any insight.
Automotive tire Motor vehicle Automotive exterior Composite material Grille
To quote Shadow, the big gains are to be had aft the Turbo.
Buying, modifying or building a better swingvalve is very beneficial.
I like to start with a 3" downpipe with no neck down, right off the Turbo.
3" downpipe, even with a 2.25" swingvalve has worked well for me.
  • Like
Reactions: 2
Even with a ported head l usually port exhaust mani 1/16” larger all around. So as long as the head ports are all Clear going into mani your good
  • Like
Reactions: 1
Did you just adapt the 2.25 donut to a bigger pipe? I know fwd perf only specs their 3" downpipe for the 2.5" donut.
No donut, just a 3" pipe with a larger flange and stock attaching bolts and springs.
A talented muffler man friend made it for me and it never leaked.
Been running it for about 15 or more years.
Simplest and brilliant !!
  • Like
Reactions: 2
To answer your question, it will be a wasted effort to widen the exhaust port (port match) to the gasket limit. There is a gain bringing it up to the gasket limit on the roof of the exhaust port. When I port cylinder heads I'm gaining over 50 CFM on the exhaust side @ .500" and I'm not even at the gasket limit aside from the roof. Like others have stated, just make sure the exhaust manifold port is as big or bigger than the exhaust port on the head.
  • Like
Reactions: 1
Thanks.
