1 - 5 of 5 Posts
Got all my gauges installed. I'm pretty happy with how it all turned out.
The gauges are:
-Wideband
-Mechanical Boost
-Mechanical Oil Pressure
-Mechanical Water Temp.
-Voltage
You can see on the first picture on the lower dash, above the drivers right knee, there is a potentiometer, so I can dim the lights on the gauges if I desire. Also notice the switch above the wideband... that's for my dual stage boost controller. Off is 10 psi, on is 14 psi. (these will eventually change since I finally have a wideband and can monitor fuel, I will now be modifying the car since I can keep a close eye on everything.
1 - 5 of 5 Posts
