1 - 2 of 2 Posts
After seeing all the people interested in doing 16V swaps, and the constant recurring questions, I felt the need to compile this list of information and links. First, is the most complete list of items you will need to complete the swap that I could come up with. I hope I have included everything, but undoubtedly I have forgotten something.
The info listed is mostly listed on Kevin's (OZspeed) site.
Secondly are a list of websites covering information on performing a 16V conversion. Again if I have left anyone out, I apologize, but this list was made in haste, and I only covered the sites I could find easily.
Lastly are the links to important threads her ein the 16V section. There are many important threads here that you will find valuable if you are performing a 16V conversion. READ THEM.
I sincerely hope that this helps guide anyone considering a 16V conversion.
Heath Farquhar
16V conversion parts list:
1989 2.5 block with venolia forged pistons, fresh rebuild bottom end, all new components minus rods.
2.0 or 2.4 dohc head complete
VW superV head studs# is 204-4202 (arp) or FWD 88-0661 (fwd performance)
www.jgstools.com/turbo stage 2 turbo header (Hope it give me enough room in the L body)
FWD performance Cam gears PN FWD 88-0658
Loctite 620
T249 Timing belt FWD 88-0662
MLS neon Headgasket
3 steel plugs .695" to .700", 3/4" long
2 steel plugs .350", 3/4" long
2 dowel pins PN 4448856
1 Aeroquip -12AN to 1/2NPT straight
1 Aeroquip -4AN to 1/8NPT straight
3 .550 Aluminum plugs, 1/2" long
1 Aeroquip -8AN to 3/8NPT straight
1 Aeroquip -4AN to 1/8NPT 90 degree
1 Aluminum 3/8"NPT Hex Head plug
t1 fuel rail
caravan fuel rail
intake manifold off of a '99 Caravan with a 2.4
Magnecore 8.5mm Plug wires FWD 88-0657
Websites for performing the 16V conversion:
Kev's Conversion Website
http://home.comcast.net/~ozspeed/
FrankNBeans
http://www.franknbeans.com/hybrid.html
Russ Jerome
http://hometown.aol.com/russjerome/
Unknown
http://www.members.aol.com/mopartek/hybrid.html
Scott
http://www-unix.oit.umass.edu/~sdeandre/Web Page/hybrid_page.htm
Threads in the 16V conversion section of importance:
Oil restrictor for head:
http://www.turbododge.com/forums/showthread.php?t=44944
Custom intake thread:
http://www.turbododge.com/forums/showthread.php?t=39800
Block and head plug info:
http://www.turbododge.com/forums/showthread.php?t=45979
16V 2.2 pics&Thread:
http://www.turbododge.com/forums/showthread.php?t=49976
http://www.turbododge.com/forums/showthread.php?t=51486
Russ's Oil drain Aid:
http://www.turbododge.com/forums/showthread.php?t=57536
FFWD Hybrid Pics:
http://www.turbododge.com/forums/showthread.php?t=55525
CAM INFO Neons.Org
http://neons.org/forums/viewtopic.php?t=85824
Neon Head Oiling:
http://www.turbododge.com/forums/showthread.php?t=67461
Part numbers for aeroquip parts
1 Aluminum 3/8"NPT Hex Head plug – FCM3687
1 Aeroquip -12AN to 1/2NPT straight – FCM2010
1 Aeroquip -4AN to 1/8NPT straight – FCM2001
1 Aeroquip -8AN to 3/8NPT straight – FCM2007
1 Aeroquip -4AN to 1/8NPT 90 degree – FCM2031
I also went to Scott D'Andre's webpage and looked up the part numbers for the fittings he used.
2 - 12an to 3/4" npt straight adapters (for the oil return to the block) FCM2011
1 - 10an to 1/2" npt straight adapter (for the oil return from the turbo) FCM 2009
3 - 3/8" npt aluminum/stainless steel square head plugs (plug the oil return holes in the head) FCM3687
1 - 4an to 1/8" npt 90° adapter (taps into the side of the head to feed oil into the head) FCM2031
1 - 12an to 3/4" npt 45° adapter (for head) FCM2025
1 - 12an to 3/4" npt straight adapter (1 for the head 2 for the block) FCM2011
For the Oil Lines:
1 - 12an straight hose end (connects to the 12an to 3/4" npt 45° adapter for the external oil return from the head to the block) FCM1015
1 - 12an 45° swivel hose end (opposite end of the hose w/ the straight hose end) FCM4025
2 - 12an 90° swivel hose ends (both on the same hose for the 2nd external oil return from the head to the block) FCM4035
1 - 3' section of 12an braided line FCA1203
1 - 3' section of 10an braided line FCA1003
1 - 3' section of 4an braided line FCA0403
1 - 4an to 1/8" npt 90° adapter (turbo feed: screws into the oil inlet of the turbo) FCM2031
2 - 4an to 1/8 npt 45° adapter (turbo feed: taps into the oil distribution block, Oil supply for the head: feeds oil to the head) FCM2021
1 - 10an to 1/2 npt 90° adapter (taps into the oil return adapter) FCM2039
Thes part numbers are for individually packaged parts in anodized blue. For bulk packaged parts the second letter becomes a 'B' instead of a 'C'. Nickel plated parts have an 'E' instead of the 'M'.
And more related links:
http://www.juxsa.com/carstuff/16v/16v.htm
http://www.geocities.com/shelby16v/?200617
Mike's updated link:
http://www.maximumpsi.com/hybrid.html
Off the shelf Hybrid parts like sprockets,pistons,wires ect:
http://www.fwdperformance.com/store/Category.asp?IDCatalog=88&txtCatalog=Hybrid 16V Neon
Cam sprocket options from Larry:
http://www.turbododge.com/forums/showthread.php?t=42983&highlight=cam+gears+sprockets
Cam sprocket options from Whywoody:
http://www.turbododge.com/forums/showthread.php?t=107721&page=2
2nd page, a20a Honda sprockets, 12v SOHC of 88-89 vintage.
Plug wire options:
Autolite 96517, older toyota v-6, have to modify dist end with
your present 8v ends (ez).
Common problem, camshaft alignment from 2.0 to 2.4:
http://www.turbododge.com/forums/showthread.php?t=94367&highlight=camshaft
(Holes in cam's point up, dont look at keyway/dowl)
2.5 STOCK BLOCK/PISTONS WILL ACCEPT THE 2.0/2.4 HEAD.
2.2 STOCK BLOCK/PISTONS WILL NOT ACCEPT HEAD UNLESS
PISTON MODIFICATION ARE MADE (HYBRID PISTONS ARE
AVAILABLE THRU OUR VENDORS). VALVE CLEARANCE IS THE
ISSUE.
DO NOT USE AN 8V HEADGASKET FOR HYBRID, ONLY
USE A DOHC 2.0/2.4 GASKET. NEVER SEEN A NON
MLS (multi layer steel) BUT AS LONG AS IT IS DESIGNED
FOR THE NEON/STRATUS YOUR GOOD.
1 - 2 of 2 Posts
