1 - 5 of 5 Posts
I was just woundering if this is normal,my daytona almost gets to the "H" on the temp guage befor the thermostat opens .I have already replaced the thermostat and the fan is on and system pressure tests ok.This only happens after a short drive (around the block)and when it idles ,after it opens no more high temp.If you go a few miles it never gets that hot only short slow drives.Is this normal?
Mr. Moderator
did you do the thermostat mod? It shouldn't be getting that hot. Does it smoke or act likes it getting hot before the thermostat opens?
mod?No smoke no funny smells but @ idle it will stay just below the h for maybe 30 sec then drop radicalyback down please tell me what he mod is
Mr. Moderator
Donovan's Dodge Garage go to number 27 and look at #2. The mod will let a small amount of coolant in, lessening thermal shock and keeping your engine a little cooler.
1 - 5 of 5 Posts
