1 - 14 of 14 Posts
I realized whatever smart guy had the car before me replaced the accelerator cable with some super long and odd cable. It was working but is deinfitely the wrong part. The cable is almost two feet longer than a stock cable and the bracket had holes drilled to adapt it to the 52mm TII throttle body. I purchased a new one that was listed as fitting the 1986 GLHS and the lengths and type seem completely different. I'd like to return the car to the stock setup. Attached are photos of the cable I purchased (the box) and two pictures of the ends of the cable to compare. It seems like the new cable has the right firewall pass through type so that is promising. The length of exposed cable is different between the two cables. I haven't attempted to install the new one just yet. I'd like to have everything lined up before doing the install. Anyone familiar and know how the cable and bracket are supposed to look?
276101
Box for new cable
276102
Pedal end: old on top with all hardware. Notice I lined up the firewall stop and the cable sticks out more on the old unit.
276103
Throttle Body End: Completely different besides the shape that fits into the bracket which appears to be a square shape for both.
Im at a loss before I didn't take it apart and can't find any clear image or explanation.
I do not own one so I cannot get you actual pics, however, take a look in the Chrysler Parts catalog to get an idea.
1986 Catalog, Group 14 Fuel Systems, Page 488, Figure 14-3900
(Throttle Control L-Body - Turbo Charger)
Closest image to the cable and bracket I have is in a pic from this 1990 Consulier GTP.. 🤔 Looks like the bracket I have but the cable I have has a smaller end stop . gdamn I didn't think this would be such a frustrating part of the restoration. I guess I just need a T2 cable bracket and cable and I'll be all set. Preferably from an 86 GLHS T2 setup
276104
If the CA8309 doesn't fit your cable bracket, and looks like the one on the Consulier, you have the wrong bracket on your 86 GLHS. The bracket should not look like the Consulier bracket. Here is a bone stock 6K mile GLHS. I've put that CA-8309 on my TII transplants and it works fine.
Discussion Starter · #6 ·
This sucks but is sort of fun to figure out.
Check this out: old pic of the setup i'm dealing with. seems funky
276106
That picture sort speaks volumes about our TD's. Lot of things happen to our car's over the years. If only they could talk! Cover over drivers end of cam that's a 84-85 Turbo only thing. The black valve cover suggests 87+. 1 piece intake is suggests 88+ TII (if it has drilled charge temp sensor). TB bracket is newer yet. Then all the aftermarket stuff.
It looks like you either need to replace your throttle cable or your bracket to have a matched pair.
Discussion Starter · #8 ·
Oh the Tales they would tell!
My guess is this motor and turbo setup came out of an 88+ car and they did not have the right throttle cable and bracket.. I know the motor was built and refurbished when the TII setup went in. I have the one piece intake and it is drilled along the front for a sensor and a vacuum port and the sensor is plugged in so it must be functional. It is running an 86-87 stage 3 front wheel drive performance tune with 15 psi boost. The entire computer was replaced including that module that has the open 3 inch hole that looks like air passes through it. They missed a few things and I'm finding all of the sketchy areas of the wire harness as I restore the car. .
When this thing is done it is going to basically be #456 GLHS in an 85 GLH-T body and running an 87 T2 motor with an 88 1 piece intake and 525 transmission unfortunately.
At the moment, I can tell you that the throttle cable on the 1986 & 1987 GLHS is different than a 1986-7 Shelby Charger.
Throttle cable assy. for the GLHS cars is 4288197
Throttle cable assy. for the standard Turbo I Shelby Charger is 4306190
How they are different, I don't know, but I'll guess it's the length.
NOTE: The 1986 GLHS, 1987 GLHS, 1987 CSX and Lancer, all use the same throttle control cable #4288197
Discussion Starter · #10 · (Edited)
That's good to know and I checked out the part number you mentioned. It is the same cable as what I posted up here "CA-8309" and comes up as an alternate part number PIONEER CA8309 Accelerator Cable | RockAuto
So I have the right cable. . Now I need the right bracket. .
Discussion Starter · #12 ·
The throttle cable mounting bracket is 4288199
Thanks for giving that bracket number. I'll keep it for reference if I stumble across the right bracket. I searched every variation and term I could and looks like thats a discontinued mopar part number.
Is that the number stamped in the side?
That's the p/n in the book.
I'll be back at the car on Monday to take close-up pics of the throttle linkage and the bracket.
Here's a long view of the bracket:
276112
1 - 14 of 14 Posts
