My box from FWD Performance arrived. The contents of which containing 2 sets if intermediate shaft bearings so i have two more chances to get them installed correctly.
Additionally, i removed the main seal housings so that i could paint them and reinstall with anaerobic sealant.
Here is reassembly after intermediate shaft installed, Mellings oil pump, original pickup with now enlarged sucky hole, and freshly painted seal housings reinstalled.
Wix filter came pre dented....
On to the head.
So ya, Todd, i forgot to drill the damned head bolt holes til after id cleaned and painted the head... So i popped them out to the 15/32" you had recommended previously. After that clean up, i moved on to assembly.
This is the results of the comp valve job grind and backcut valves.
I was excited to find Manley part numbers on the valves. Score!
Unfortunately they are not oversized...
Here are all of my cobbled together parts for the job.
I didnt capture the Comp beehives that im using. Otherwise titanium retainers, LS1 valvestem seals i believe, VK144 7* locks for the intake valves. Im not happy with the fit of the 3groove locks so im going to try another brand and application.
Lastly im dead in the water for the real assembly because ive misplaced all of the valve spring seats/shims that i own. So i ordered some sets of .030" and .015" to get it dialed in.
Thanks for watching,
~Mark
