Hello Gents:
I made the rail for John and I can tell you that based on the data I've collected thus far (in terms of both dyno testing and from speaking with a couple guys who have some of the world's fastest Buick GNs) there is a constant pressure across the entire rail (from left to right as you are facing it) and when the injectors fire - sequentially or in batch depending on year and software of SMEC/SBEC (open - measured in ms) more fuel is continually/instantly entering the rail (from the passenger/feed side) and it makes no difference if the regualtor (which is returning fuel to the tank) is located on the left side of the rail, in the middle, or on the opposite end. In *theory* one would think it would be beneficial to have it located on the opposite end of the feed side but in *reality* it just isn't necessary. My car belted out over 500hp at the crank (443SAE ~462STD WHP) with an identical fuel rail to this - over and over and over. That's not what happened in theory.....that's what happened on the rollers.
When we pulled the plugs after the runs all 4 plugs looked identical. Admittedly the motor was getting lean towards the end of the day (as I dropped my base fuel pressure more and more and watched the power go up and up). My first pull (if memory serves me) was 392 SAE WHP at 18psi boost. I can pull up the dyno sheets to be sure. I have copies of the dyno sheets if anyone is interested. I did this back in 2000. The car has been sitting (with boxes piled on top of it) for quite some time now. Car ran a best of 11.40 at 128mph on 7" wide slicks, with so much wheelspin that I never got a decent ET out of it. I watched as an RX-7 ran a 10.40 at 127mph the following day. A fellow Shelby/Dodge Auto club member was there to witness the car make 21 passes, most of which were back to back (the track was rented out that night by the company he works for - a tire manufacturer). He asked me to bring the car so he could show some of his buddys that he works with the car and so that I could get some decent runs out of the car because on a typical night you're lucky to get in 3 runs (all of which are usually about an hour apart).
The rail works. None of the injectors are starved from what I've seen in testing. Any questions feel free to drop me a line.
Regards,
Rick Diogo
RDI Performance
87 Shelby GLHS #160 - 16v
