I may be interested in this if someone can provide details. P-body here also.
Mine was 1 inch. Had to cut away a bit of the webbing inside the hood for it to fit without rubbing. It still may of a tiny bit at times when the engine rocked.Does a tona have clearence for 1inch?
the spacer is to cut down the curve that is very sharp when the upper is joined to the lower. it also cuts heat down from getting to the upper. i have seen estimates that put the HP gain from 5 hp to 8 hp.Can someone describes me this spacer and what it is used for ?
sorry my friend but these are for the 3.0. the 2.5 has no such spacer.Thanks
It is made for the 3.0 engines ?
If it works with the 2.5 turbo, I'm also interested (P body)
Don't know the price though
NOOB!!!!!:lmao:my bad, i thought that these would be for the 8v motors
sorry guys
if you want one, it shouldnt be hard to fab up. I made mine by taking an intake gasket and scanning it on the computer. i then used the class computer controlled laser cutter machine of awesomeness and had them cut out of 1/4inch mild steel. 4 spacers later i have 1/2inch total for each sidemy bad, i thought that these would be for the 8v motors
sorry guys
