Have a set of GRP Al rods for common block. Less than 500kms run time. 350 plus shipping
PM any questions
PM any questions
Rods are Sold!these are for 927pins. When these were installed the machine shop wasn’t aware of having to make sure both sides of crank journals were clean and clear of any rough casting. 1 rod on one side has several thou removed. View attachment 285665
Agreed, and this was an engine that I only got involved with after customer had gotten all the parts and used a cast 2.2 crank. I should have inspected Everything myself. Just shows that machine shops that aren't use to certain builds can miss things and often do.Yep, side clearance is critical esp. in aluminum rod applications, vertical clearance too. I made up a fixture to drill those bearings for the pin in the cap.
