1 - 8 of 8 Posts
My fan took a crap a while ago. The frame work for it is specific to the car(92 r/t), the fan motor is the same as a bunch of others. This is the radiator fan. anybody taken one apart that can tell me how to get it out of hte frame? i took the clip off the inside, 3 screws, what else do i need? do i need a puller of some sort? this is on a slim fan from a 3.0 Acclaim
are we talking about getting the blade off the fan? If so I have seen 2 types. One uses a nut and the shaft has 2 flat sides the blades key to. The nut is left handed threads and once removed a little penetrating oil and the blades will work off. The other uses a clip. The motor shaft has a roll pin through the shaft that keys the fan blades on. Again a little penetrating oil and the blades should come off after the clip is removed. If were not talking about what I just wrote got a picture?
Tim
I was out looking at mine today because of this thread. Pop the clip off and pull the blades off. Unbolt the 3 screws and pull the motor out of the frame. What part of that isn't working? it the blaed are messed up they might be difficult to get off.
Tim
Bfh!
i took the screws out and the clip off, blades wont come off. thats the problem i'm having, dont know why, but but it doesnt wna come apart
pain in the rear. i did it and changed the motors. i dont recommend it.
what was the problem with getting the blades off? I've taken 2 off latley and they came right off.
Tim
1 - 8 of 8 Posts
