if they are brand new bolts they should be ok...i think you can use them 2 or 3 times......just visually inspect them when ya pull them out if they arent warped/streched i would use em again
You're right it is silly. But prior to posting this I already tried getting to it from underneath the car. Even removed the wastegate.Stevien1 said:Before pulling the head, try reaching over the top of the K-frame from underneath. Unless it's an L-body, you should be able to get to the oil feed on the turbo. If you can't, try removing the front mount and rotating the engine/trans forward with a prybar or even a ratcheting cargo tiedown.
If you need more working room around the turbo, remove the wastegate actuator and coolant return line. Give it a shot, seems kind of silly to pull the cyl head for a loose oil feed line.
-Chuck James
^ very good point.looneytuner said:Don't use teflon tape. Use the liquid teflon. I pulled some lines pefore starting engine and the tape was just shoved out of threads.. That may be your problem.
Yeah I have had that happen before, but in the past it was always because the tape was wrapped around the threads in the wrong direction. For right hand threading there is only one direction the teflon can be wrapped around, or it will come off the threads when tightenedlooneytuner said:Don't use teflon tape. Use the liquid teflon. I pulled some lines pefore starting engine and the tape was just shoved out of threads.. That may be your problem.
I agree. I too have done it, and there were no ill effects.adam89shlbydayt said:the bolts and gasket should be fine to re-use, i have done it before, since they havent had any heat or press. on them.
I've done this too. I sprayed some copper sealer on the gasket just in case, though. Car still runs like a champ several 1000 miles later. Boosts to 12 psi on regular gas even. This is on my winter beater.adam89shlbydayt said:just for the record, i have re-used a used h. gasket and bolts
