Im looking to put an order into TU ASAP but building this G-head, I need to make sure I get the right gaskets for everything (valve seals, headgasket, and valvecover seal). TU has 2 different ones... does anybody know what I should use? I want to use my valve cover off my current head and its going on my 2.5L commonblock for my mini (no cross drill on new head done).
Thanx!
JW
dont take my advise too seriously because I dont run an 8valve, but i read alot. The 005 gasket is the "one" to use cross drilled or not AFAIK
Discussion Starter · #4 ·
:D Yeah, I asked that one the other day. The problem is, they don't list which head gasket comes with what. On top of that, I do not know if the valve seals are the same between heads/years. Then of course there is the valvecover gasket... not sure what the difference is there either.
Seals are the same I believe. The difference in the VC gasket is between a 1pc and 2pc gasket. I would think that the pre 88 would be the non cross drilled.
Why wouldn't you just call Chris at TU and ask him? Could have had it ordered by now.
Discussion Starter · #7 · (Edited)
I went to the contact section, it was just an email thing. I couldn't find the number (gave up easily though after not seeing it in contact). I wrote in that contact part about 2 days ago? Maybe it was yesterday, memory fails me.
EDIT: I went to their very first page, before the store, and went to contact and found the number there! Thanx guys!
