1 - 11 of 11 Posts
90 daytona 2.5 turbo, 14 psi, i have detonation problems
head and block surfaced
should I be using a head gasket shim?
if i dont, should i be changing cam/ignition timing?
according to my calculations a a reduction of 0.020" from the combustion chamber is equivalent to losing 3.1cc's from the combustion chamber volume, which when starting at 55 cc's is about a -6% change. Im not sure if im starting with 55c's though. This is based on a bore diameter of 3.475" (2.5 turbo oversized 0.030") which im not sure is correct either. lol
I used to run an .060 shim in my 2.5 Shelby Lancer, it allowed me to go to around 21psi boost on pump without having to crank the ignition timing way back:cool: That was big boost back in those days:eek: I also threw a 3 degree offset cam key in there to make up for the timng change.
Alan
acannell ... detonation can be caused by many contributing factors. Lets step back a second and review your set-up.
You don't say how much was removed from the deck or head ... do you know?
Have you gone over your cam timing? Over advanced cam timing can raise internal engine temperatures, causing detonation.
Internal heat is a big killer.
So,
Cooling system up to snuff? What range t-stat are you using? Running a 50/50 mix in there or something else? Radiator in good shape? Water pump new or used?
Oiling ... basic questions. Type and weight?
14 psi isn't a ton of boost. I know from your other posts that you're using a WB (and EGT?). Looks like you're getting plenty of fuel but other than the WB reading on that how do you know? Did an injector skip a beat? <----- EGT reading would usually show this as low temp.
Injector wiring good shape? ... connections solid?
What fuel pressure are you set at?
Does it rise while boosting?
Fuel filter new?
Your issue may have been just a bad tank of gas.
Trick I'd try to trace detonation issues that might be fuel related is this. Get (9) gallons of fuel in the tank and head to a paint supply store. Buy a gallon can of either Xycol or Toluene. Pour it in the tank.
This will raise the octane of the fuel pretty high. If he detonates under these conditions you definitely have another problem .... if the fuel delivery system is OK otherwise (wiring, pressure and volume).
If he doesn't detonate could be a change of gas stations is in order. Or, a reduction in boost level because of a area wide fuel issue in your locale.
Didn't go over the ignition too much ... assuming you're at stock (12*) timing ... stock plugs? Again, not a lot of boost so stck plugs might be fine but dropping a heat range given your problems might be in order.
I know you asked about MBC's vs comp controlled boost ... don't chase your tail. This is a non-issue. I would get the ECU sorted out for nothing else but timing and fueling tables to match your goals.
Good luck.
Discussion Starter · #7 ·
block and head surfaced a total of less than 0.020" i believe, this would be equivalent to about 4 ccs reduction in combustion chamber, which is almost 10% of 48cc's! that could be it couldnt it?
cam timing should be stock (just set it)
radiator is new, water pump is new, coolant is mostly water
oil was 10w30 mobile 1
injector wiring was old... so i just replaced the injector harness connector and HEP sensor connectors with solder joints
fuel pressure is now at 29 psi with +40 injectors
fuel pressure does rise while boosting
fuel filter is new
i tried octane booster (the good stuff worth 60 points or 6 R/A numbers) and still got detonation, should I still try the toulene?
plugs are now autolite 63
im glad to hear you think MBC's are okay because the computer spools up slow and doesnt go above about 10 psi.
okay so my combustion chamber is 10% smaller than stock, AT LEAST, and NOT INCLUDING the fact i have oversize pistons, which will raise the compression ratio EVEN MORE. maybe thats it?
a shim is sounding like at the very least a no-brainer, even if its not the source of the detonation problem...
yeah like I said, according to my calculator, removing .020" shows .3 Increase in CR. Also instead removing 4CC's gives the same .3 increase in CR(so I think thats right.
Then the .030" over bore adds a little over .1CR increase if the dish volume and height are the same(which most pistons are like this)
These are ruff estimates as I dont know the exact 2.5 specs, but I started with 7.95CR and after changing the things above ended with 8.4CR as detailed above. An increase of .45 in CR.
acannell If you have Microsoft Excel and PM me your email address I'll send you this sweet CR calculator someone on here sent me.
.020" is quite a bit. That'll raise your CR about .6 or so. No way of knowing on top of what exactly because we're working with nominal factory CR statements. You could be lower than that already ... you'd have to have measured it to be exact. Being realistic though ... if your wanting more boost in the future ... a shim is probably in order. If you're happy at 14-15psi I'd leave it alone. 8.6x:1 responds nicely.
Just a gut hunch on my part leans toward some bad gas or fueling issue as the cause of your problems (cracked ring lands). BTW, What product states a 6RON increase in octane? That's an assload to be sure ... especially if it comes in a 4oz bottle (lol). It takes a gallon (9to1 ratio) of the xycol or toulene to raise the octane (4-5RON) or there about. The side benefit of those chemicals is the increased power at the flywheel.
Octane Booster - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Longish thread but very informative.
http://zhome.com/ZCMnL/PICS/detonation/detonation.html
Another worthwhile read.
Discussion Starter · #10 ·
i'm totally open to the octane booster i used being bullcrap, but it was gold eagle 104+ MAXIMUM (lol)
Skip that garbage in a can stuff and just put a few gallons of Union 76 100 octane in with your fill up. 3 gallons of that in a tank can work wonders with our lousy 91 octane premium:mad: Then test it all the way to the SoCal meeting a week from today:cool:
ALan
1 - 11 of 11 Posts
