1 - 8 of 8 Posts
Ok so this is kinda a dumb question but I need to ask it anyhow. I just replaced the heater core in my 89' Daytona and I'm currently stuck on the re-assembly process due to this wire. It's the manual lever that uses the wire instead of being vacuum controlled. No matter which way I try and run the wire it gets bound up when connected to the lever which results in the lever not being able to slide back and forth. I would love for someone to snap a photo of how this wire is suppose to run. In the mean time i'll keep trying different routes but its driving me crazy.. thanks in advance!!
Thanks Naj but I think mine may not be adjusting seeing how the cable won't move enough to let me re-install the heater control back into its original mounting position. I'm thinking the way the cable is run right now is my problem. seeing how its making a turn that ends up being > *90 making a big C and forcing it to bind.
1 - 8 of 8 Posts
