1 - 15 of 15 Posts
Vacuum leak somewhere. Usually if it keeps revving like that, it's a pretty big one, like the brake booster line or something.
gary's site said it is the pneumatic MAP sensor or something to that effect, thing is, what the hell does that mean?
The MAP sensor gets its reading from the vacuum/boost in the vacuum lines. (Pneumatic = air) If there is a leak somewhere, the MAP will pick up an erratic reading and throw a code.
And yeah, I'm not sure when code 12 actually goes away, it's lasted months and months for me.
yup...it did the same thing for me. I re-did the vac lines and it went away.
same here with my 85 GLH-T. It would stay around 3K at idle. changed computers . . nothing, changed Throttle Position Sensor . . . nothing, redid some vacuum lines . . . never happened again. that is probably your problem.
Jake Bauer
i thought code 12 was "start of codes"
hah....it would seem so after awhile huh? It just means your battery has been disconnected/died in the last 40 starts.....I'm sure most of you guys get to the 39th start and then for one reason or another, you have to unplug the battery again!! :rolleyes:
-Lee
1 - 15 of 15 Posts
