Well me and Dragbaron were working on my Shadow today.
I was driving on the highway to school and then I totally lost power. Next thing you know I couldnt turn the car on. I was not getting any spark.
Dragbaron pulled me back home to see what the issue was. Finally we diagnosed it down to either the HEP or distributor. Well we pull off the HEP to see the distributor and we find out the little metal fins in it broke off there welds.
Well without finding any distributors locally at any parts stores or junk yards, dragbaron looked in his shed with car parts. Finally he came across a Distributor he pulled from a 87 Lebaron Turbo car. It looks exactly the same except it has a little window on one of the metal fins.
We put it on to see if it works and it did!
BUT the car had a high idle once the new distributor was one. The car now sits at 2000 rpms.
I am curious if you think that the turbo distributor with the window in the fin is causing the high idle?
We already checked for vacuum leaks and repaired all leaks.
Also we did that IAC idle reset where you disconnect the booster hose and then the IAC connector (while running) and put the booster hose back on (still while running). Then turn the vehicle off and then plug the IAC connector back in.
When it is turned back on it idles fine(900-1100RPM's) for about 5-10 seconds and then the idle jumps right back up to 2000RPM's.
Also we checked the ignition timing and we have it timed perfectly.
Any idea what I should look into next?
Maybe a new distributor specificlly for TBI car?
Or new IAC?
We are stumped.
Thanks for any help.
Or new IAC?
We are stumped.
