1 - 5 of 5 Posts
I get a high idle (on a cold start)when its below 45 degrees or so. It starts at normal rpm then jumps ( after like 30 sec)to prob over 2 grand and surges(a bit).
This happens even after the van is well warmed up randomly.
I can remedy this sometimes by a restart...then sometimes normal idle returns.
any ideas?
I will pull codes next...
Scott
AIS is the solenoid that adjusts the idle, its located at the bottom/driver side of the throttle body (on turbos).
1 - 5 of 5 Posts
