I have a hx35 that I'm going to put on my spirit. I was wanting to know if you guys just run the internal wastegate that comes on the hx35 or do you guys run a external setup.
I'm having some issues on my 8v with boost creep with a he341 so I would suggest porting the waste gate port just a bit help with that. Just a suggestion that's all.
I'm running the HE351, and installed in "stock", take off form I couldn't run less than 29psi. Pulled off the hot side of the turbo, and ran a 1" carbide bit through the wastegate passage, and now it'll run all the way down to 12psi. I believe the initial diameter of the wastegate passage is 3/4 or 7/8.
Turbo Dodge Forums
