Connect fuel pressure gauge to service valve on fuel rail.
Static Rail Pressure(key on/engine off) on a MPFI is 53-57 PSI.There are 2 ways to test.
1) Turn the key on then off,wait a few seconds turn the key on then off, you may have to do this a couple of times until all air is purged and the rail and gauge are at max regulated pressure.
2) Locate the underhood diagnaostic connector(in the harness by the controller) and with the key on/engine off ground the DB/YL wire, this actuates the ASD relay and the pump will run, read pressure.(Do Not start the vehicle with the wire grounded)
Checking running rail pressure
Start the vehicle and read pressure, rail pressure will drop 1 PSI for every 2" vacuum applied to the Fuel Pressure Regulator.
(MPFI works on Pressure Differential across the Injector, but that is for another day)
Ex. Static Pressure = 55 PSI, Vehicle running rail pressure drops to 46 PSI with 18" Vac at the FPR = 55PSI.
Check Pressure at 2000 RPM's.
This is easier if you tee a vacuum gauge inline with the fuel pressure regulator so you can read pressure and vacuum at the same time.
All Readings should be equal to static rail pressure.
With the engine running if you remove the vacuum from the FPR rail pressure will increase to static rail pressure(this is max regulated pressure)
If you are going to check while driving fuel pressure will increase 1 PSI for 1lb of boost.
When the engine is shut off pressure should hold, if it drops suddenly there is a leak in the system.(pump, fpr, hose, injector(s) etc.
