1 - 2 of 2 Posts
its a 2.5 turbo I common block. the head is off. its in-car.
there is a pretty serious leak between oil and coolant SOMEWHERE. oil looks like a latte from starbucks and the radiator is filled with goo. it may have been the headgasket. i have a new head enroute so it doesn't matter if it was the head.
i just want to make sure it wasn't the block
is there some way I can pressurize either the oil or coolant passages in the block to see if it leaks into the other? or some other trick to see if it leaks? i dont need to know WHERE its leaking, just IF its leaking
1 - 2 of 2 Posts
