Bunch of stuff for sale CHEAP on Ebay- Low opening bids and no reserve.
http://motors.search.ebay.com/_W0QQsassZ2000lfd
DODGE SPIRIT R/T 16V ENGINE COMPUTER NO RESERVE
DODGE SPIRIT R/T 16V DRIVERS "A" PILLAR TRIM !MINT!
DODGE SPIRIT R/T DRIVERS ELECTRIC SEAT TRACK & CONTROLS
DODGE SPIRIT R/T 16V CYLINDER HEAD VALLEY COVER
DODGE SPIRIT R/T 16V UPPER TIMING COVER MINT!
DODGE SPIRIT R/T 16V AIR BOX AND SNORKLE ASSEMBLY
DODGE SPIRIT R/T 16V INTERCOOLER PLUMBING AND BOV
DODGE SPIRIT R/T MANUAL PEDALS & CLUTCH CABLE ASSEMBLY
DODGE SPIRIT R/T 16V NGK SPARK PLUG WIRES $5!
DODGE SPIRIT R/T TURBO DOHC 16V SERPINTINE BELT $5!
DODGE SPIRIT R/T TURBO 16V A/C LINES
DODGE SPIRIT R/T TURBO FRONT MARKER LENS $5
DODGE SPIRIT R/T 16V RADIATOR, INTERCOOLER & FAN
DODGE SPIRIT R/T 16V A/C COMPRESSOR
DODGE SPIRIT R/T 16V ALTERNATOR
DODGE SPIRIT R/T DOHC 16V P/S PUMP
DODGE SPIRIT R/T DOHC 16V COIL SPRING SET (FOUR)
DODGE SPIRIT R/T DOHC 16V CRANK SENSOR!
DODGE SPIRIT R/T DOHC 16V CAM SENSOR!
DODGE SPIRIT R/T DOHC 16V COIL PACK
DODGE SPIRIT R/T DOHC 16V 52MM THROTTLE BODY
DODGE SPIRIT R/T DOHC 16V THROTTLE CABLE
DODGE SPIRIT R/T DOHC 16V CHARCOAL CAN
DODGE SPIRIT R/T DOHC 16V VACUUM HARNESS
DODGE SPIRIT R/T DOHC 16V RADIATOR HOSES (2)
DODGE SPIRIT R/T DOHC 16V ENGINE HARNESS COMPLETE
DODGE SPIRIT R/T DOHC 16V 568 MANUAL SHIFTER & CABLES
DODGE SPIRIT R/T DOHC 16V MANUAL CONSOLE AND BOOT
DODGE SPIRIT R/T DOHC 16V HEAD & DRIVING LAMP SWITCH
DODGE SPIRIT R/T DOHC 16V LEATHER STEERING WHEEL
DODGE SPIRIT R/T 16V LOWER TIMING COVER NICE!
DODGE SPIRIT R/T 16V VALVE COVERS WITH BOLTS
DODGE SPIRIT R/T 16V INTAKE, FUEL RAIL, INJECTORS, BOLT
DODGE SPIRIT R/T 16V WATER PUMP, BOLTS, BRACKET, PULLEY
DODGE SPIRIT R/T 16V SERP BELT PULLEYS & BOLTS
DODGE SPIRIT R/T 16V A/C & ALTERNATOR BRACKET
DODGE SPIRIT R/T 16V P/S & SERP TENSIONER BRACKET
DODGE SPIRIT R/T 16V FLYWHEEL $9 FLAT RATE SHIPPING!
DODGE SPIRIT R/T 16V DOHC EXHAUST MANIFOLD & STUDS
DODGE SPIRIT R/T 16V TURBOCHARGER COMPLETE!
DODGE SPIRIT R/T 16V EXHAUST CAMSHAFT - NICE! -
DODGE SPIRIT R/T 16V INTAKE CAMSHAFT
DODGE SPIRIT R/T 16V TIMING GEAR SPROCKET SET
The head and some other parts will be listed in a few days.
Need to make room in the garage for a RACE CAR.
Gary
Gary
