HVAC Controls
407 Views 4 Replies 2 Participants Last post by  86GLHS481
Hi, '86 Omni, having a problem with the hvac. I can't get air to change directions when I make a selection. Can't get it to go to the floor or defrost, stuck on vent currently. My vacuum lines are connected correctly according to the attached diagram. Not sure what's going on.
1 - 5 of 5 Posts
2
Defrost is Default, if you lose vacuum to the system you automatically go to defrost, which means, you constantly have vacuum applied to the actuator for the panel, the actuator is staying actuated after vacuum has been removed or you have a mode door issue.
Unless my info is not correct, the vacuum diagram you showed is for 85-87 Except L-Body.
According to my info this is correct for 85-87 L-Body.
1)
Recheck vacuum line routing, there are 3 actuators (see items 14, 20, 24), if vacuum line routing is correct and the problem persists, continue...
Rectangle Slope Font Parallel Diagram
Font Parallel Pattern
2)
Disconnect the main vacuum source underhood and see if the air now blows from defrost only.
a)If Yes, you know you have an issue with vacuum constantly being applied to the panel actuator.
b)If No, you have an issue with the actuator binding/not releasing or the mode door is stuck in the "panel" position.
Ok thank you. I will re-route via the diagram and see if that fixes it
Is there a better diagram? Things are kind of blended in and hard to follow what goes to the main connector block.
Disregard that last request. I got it! Works perfectly now. Thank you!
  • Like
Reactions: 2
1 - 5 of 5 Posts
