1988 Chrysler LeBaron I'm working on for a family member I noticed today after replacing the battery the idiot lights do no work, none of them, airbag, low oil, check engine or brake. I'm sure all the bulbs are not blown, what could the common part be that failed?
You need to check the power sources into the cluster, you probably blew a fuse.
Thank you very much! Checked the fuses, their all OK, will dig into it more over the weekend maybe.
