Hi, does anyone know where we can find a IACV for a 1985 Dodge 600 ES Turbo Convertible, with a 2.2L engine?
Our 85 Dodge 600 ES Turbo runs great, but at idle will sometimes want to stall. Especially after the engine is warm. Our mechanic has determined that the IACV is bad. Trouble is, we can't find one! The model we have has no vacuum ports on it, and two wires coming off of it. There is not an electrical connector directly on the unit. Our mechanic has found two units, but they are the wrong type. :bang head
We have already tried Arizona Parts, Rock Auto, Auto Zone and NAPA.
Any suggestions would be greatly appreciated.
Mr. Moderator
Its just known as the AIS on these. IACV is honda lol
Its the bottom sensor. It will be older t1 specific.
Best suggestion, make a wanted post in the parts wanted. See if anybody has a new one or lightly used sensor they could part with.
I know this is a long shot but have you checked the dealer?
I posted in your "parts wanted" thread but you can test the motor by yourself to be sure the motor is the issue.
It is only a 2 wire DC reversable motor and uses a planetary gearset that opens and closes to increase/decrease airflow around the throttle plate.
Disconnect the 6 way connector and use 2 jumper wires connected to battery + and battery - and touch the 2 motor terminals in the 6 way connector.(GY/RD and BN wires)on the motor side.
Reversing the connection will make the motor move in the opposite direction.
If it moves both ways the motor is not the issue.
You can also remove the motor from the throttle body and be sure there is no dirt/debris keeping the gears from turning.
