1 - 2 of 2 Posts
Hi, all. I have a ignition problem. 83 Shelby Charger, I'm driving along and the ignition will start cutting off and on. It's random, so I can't trace it out while driving, also the Tach will shut off the same as the ignition. The radio will still play, so it's getting power. I replaced the ignition switch with a new one, but it's still doing it. Any idea as to which component to replace first and what order should I chang things out?
Thanks.
If I had to make an educated guess by the symptoms you are describing it would be...
Start the car and perform a "wiggle" test on the wiring/connectors to see if you can duplicate the condition and be sure the connectors/terminals are not loose fitting/corroded.
1 - 2 of 2 Posts
