Last night I ported my upper intake to accept a 58mm TB, installed it this morning, I had a leak that would idle around 3k rpm, fixed that and don't hear anymore leak (sucking sounds). The car idles around 1750rpm when warm, I reused the 52mm TPS and AIS since the others are not usable off the 58mm.
Only things I didn't do was reset the computer (trying it now and will test in a little while).
Will I have to set base timing again since i've ported the intake. All I did was the 58mm opening, I have not done the ridges yet due to time.
TIA!
TIA!
