1 - 6 of 6 Posts
So, I have an '87 Daytona that I'm attempting to install the slave CD player into.
I have an Infinity I deck that works and an Infinity II with a dead tape player. So I'm OK there.
I have two CD decks and the cable. One CD deck has a bracket that doesn't line up to anything in my dash.
It also looks like there may be a trim piece to surround the CD player? I don't seem to have this.
Anybody added this groovy little option to their car?? What all am I missing?
from the 1988 part book as this is the first year this option was available
CARRIER, Console
04372856 1 w/Storage Box
04460258 1 w/Discplayer
04430118 1 HOUSING, Discplayer
04220582 1 BOX, Storage, w/Cup Holder
04311270 1 CRADLE, Console Cup Holder
04372382 1 BRACKET, Carrier to Gear Shift Mounting Bracket
BRACE, Instrument Panel to Reinf.
04220289 1 Right Side of Console
04311920 1 Left Side of Console
17 AR SCREW (DNS)
18 04430122 1 BEZEL, Disc Player to Housing
19 AR SCREW (DNS)
20 04430120 1 DISCPLAYER, Compact
04430119 1 BRACKET, Disc Player Housing Mtg.
21 04469028 1 CABLE, Disc Player
RADIO, E.T.R. w/Clock
04430010 1 Innity Sound, w/o Graphic Equalizer, Used w/Discplayer
04372444 1 Innity Sound, Up to 11-18-87, w/Graphic Equalizer
04469084 1 Innity Sound, After 11-18-87, w/Graphic Equalizer, Used w/Discplayer
I have all the parts associated with this
will send you a PM
Mr. Marty,
Problem is.... I don't 100% know what I need. I've never seen one in a car before. I was under the impression it was a simple bolt-in Swap.
Through process of elimination, I have a feeling I might need these four pieces. Any chance you could send me pictures so I can compare with what I have?
4460258 is item # 16
274793
1 04469015 1 MAST, Antenna
2 04372136 1 NUT, Cap
04222723 1 WASHER, Lock
3 04372144 1 ADAPTER and PAD, Antenna
4 04372117 1 BODY and CABLE, Antenna
5 04372583 1 BEZEL, Console Trim
04220455 3 CLIP, Trim Bezel
6 SCREW (DNS)
7 KNOB, Radio
04311337 1 Bass
04311339 1 Treble
8 06031665 2 SCREW, Radio Att.
9 KNOB, Radio
04311341 2 Secondary
04311334 2 Primary
10 RADIO, E.T.R. w/Clock
04311956 1 Am/Fm/Mx Standard
04372536 1 Am/Fm/Mx w/Cassette
04220482 1 PLATE, Radio Opening, w/o Radio
11 STRAP, Radio Ground (DNS)
12 SCREW (DNS)
13 SCREW (DNS)
14 CARPET, Console Side
0V314GR8 1 Red, Right
0F321GR8 1 Red, Left
0V314FS8 1 Charcoal, Right
0F321CS8 1 Charcoal, Left
0V314GL7 1 Taupe, Right
0F321GL7 1 Taupe, Left
0V314FC5 1 Blue, Right
0F321FC5 1 Blue, Left
15 PANEL, Console Side
0P572FK1 1 Right
0P571FK1 1 Left
06031967 2 CLIP, Panel to Carrier
16 CARRIER, Console
17 AR SCREW (DNS)
19 AR SCREW (DNS)
Hmm, ok. Thanks! That really helps.
I guess all I really need is:
Thanks for that.
1 - 6 of 6 Posts
