1 - 5 of 5 Posts
I just got all new suspension (Konis all around )and bushings for my 85 daytona :thumb: but anyway I'm skeptical about the springs I bought them from Cindy and I'm assuming they are 2804's as they say it on them (Eibach pro spring kit). I read these will ride high? any experienced opinions? Another problem is the rear springs I can't seem to get them out. I rented the two spring compressors but they just seem to be too bulky and there just isn't enough room any tricks to this?
Thx, Chris
Legendary Driver
jack up rear end, let axle sag, put jack under axle to just put a bit of tension on it. Now undo the shock and the panhard bar then let the jack down slowly. You'll then be able to pull the springs out by hand.
Ya I thought so I was searching and just found a post that said to do that hehe thx panhard bar=track bar correct? I'm also having issues with the tie rod ends haven't messed with them a whole lot but it doesn't seem like its going to be easy...the whole rod seems to want to just twist is this bad for the power steering?
I got it off today just waiting for my control arms to get powder coated :thumb: ya it only seemed hard because I had the whole brake rotor assembly detached from it so i just slide the tie rod end back into the hole and was able to loosen the nut easy. It was my first time messing with the suspension I did so many things out of order lol o well Thx for your help GLHNSLHT2 :thumb:
1 - 5 of 5 Posts
