well, one of my 5 daytona's has started to have a charging issue again!!! it is the tII shelby z. when any extra load is added to the electrical system the alternator quits charging if you turn off the load, headlights or cooling fan turns off... and throttle engine it will charge again. voltage at batt is average 13.8-13.9 it goes to 11.7 when headlights are turned on. its not the power module... swapped it with my tI shelby z also swapped out my spare tII logic module. Im thinking its a short somewhere, the diagnostic manual shows a headlight to dash 8-way connector, with a dark blue wire and dark green wire that are spliced together. looking at the charging system wiring and pin outs to the power module it looks like the to wires to this connector are for the field wires to the alternator... I just dont know where the connector is located.. does any one have any ideas...
