I have a turbo vc with a straight pcv fitting currently, I changed it to a 1pc gasket already.FYI the 90° fitting and straight fitting for PCV is interchangable for early to late valve cover. The early valve covers use a 2 piece PITA gasket, while the 89+ valve covers use a more desirable 1 piece gasket. Early covers with 90° PCV should be 87 and earlier (log intake manifold) engines. Beware of scammers... They're lurking here on this forum. Demand pics. with username in pics. Good luck with your search!
Info? Price? Photos?I have valve covers if you don't find one closer.
If you have part #'s for what you want, go to www.arizonaparts.com-Power wing windows+ overhead console/switches
-blue/gray 5 speed shifter console
-turbo valve cover (90 degree pcv fitting please, but will entertain straight fitting VCs)
Sent from my LM-V600 using Tapatalk
