http://www.turbododge.com/forums/f4/f14/138458-help-poor-idle.html
would this apply to a NA motor also? because my 94 shadow base 2.5L had idling and running issues these past few weeks. yesterday i don't know exactly what i did, but i suspected a vacuum leak @ the intake manifold.
i had a vacuum gauge hooked up to the vacuum source, the speed control nipple @ the brake booster and it showed i wasn't pulling enough vac.
i replaced any dried/brittle/broken vacuum hoses, ran a smoke machine through the lines to check for leaks. nothing. popped everything back in and it ran fine. ALOT better than before and the vac gauge showed i was pulling enough vacuum.
i run to my sisters house and the car started to relapse, but the symptoms weren't as bad as before. before the idle would be surging and dying out on me @ a stop light, but would NEVER die. but since i find it annoying that the car shakes so bad when undergoing the idle search i lay on the gas pedal.
since i've somewhat fixed the problem, i'm still having slight idling problems, only not as bad as before.
i've already timed the motor. i haven't scanned for codes yet though.
