Figure someone might be looking for a set. Came out of my old bottom end that had a blowby issue due to improper ring end gap. they are oversized, i believe .020, but possibly .030 over. I went with a different block and and a set of venolias, so i no longer need these.
stock wrist pin diameter
setup for floating pins
valve reliefs for use with the t3 lotus head - non interference
$200
______________________________________________________________
also have a few common blocks sitting at the shop:
common block, oil passages cleaned, balance shaft hole plugged, painted black. ready to bore or hone to spec. currently .020 needs to go next size overbore. $75 + shipping
.030 over common block, good bores, hone or bore to spec. $50+ shipping
good condition 2.5 CB crank - $30 + shipping
