In reference to this thread
http://www.turbododge.com/forums/f4/f62/395051-konis.html
I'm thinking of going with this option. Sounds pretty straight forward. Take old strut drill hole to remove gas and oil. Cut the neck off the old strut to remove the old strut rod. Take the new Koni insert and machine off 1 3/8" for it to clear the bearing assembly. Assemble and you're done.
I have a question regarding the machining. Since the machining of the top of the strut rod is only for the purpose of clearance through the strut rod, could you not use a grinder/dremel and do it yourself (carefully of course and with patience)?
Also what kind of spring should be used with these koni's? Eibach's or shelby daytona?
