2 liftgate opening panels:
H188CAS Tan
H173CAS 2 Tone gray/charcoal
Both above fit all 1984-93 G Bodies. These nearly always get destroyed due to the brittle nature of the plastic.
Of course it doesn't help if you are throwing bricks, bodies or groceries in there. It will break.
The opening for the latch in the center is another weak spot. The tan one has survived with just a small crack
which could be glued from the underside. It does have some damage on the upper edge. The 2 tone one has damage
in the center opening.
55.00 each
H180GL7 Liftgate lower panel 1984-90 G Bodies This one has a screw hole on the end broken, but the center opening for the latch
is intact. I have others in the same condition and other colors also. (4247048 is the casting #)
50.00 each
shipping extra
