1 - 6 of 6 Posts
I'm looking for a few hard-to-find parts for my LeBaron, without paying through the nose for them.
I need the exterior mounted compass/temperature module that interfaces with the 6-button Traveler EVIC, as mine has gone bad and they're IMPOSSIBLE to find.
I also would like to find an original single disc slave CD player. My car has the factory Infinity stereo cassette, but no CD player.
And finally, I want some 16" alloy wheels. My first choice would be the Spiralcast wheels fitted to the 1992-95 GTC cars, but I also quite like the 1989-91 GTC wheels, the lace/lattice/diamond spoke with a machined lip.
If anyone has these items, and would like to part with them for a reasonable price, please, please get in touch. Thanks so much!
~Dave
***I should note, I've been looking for these parts and pieces since I bought the car a year ago, to no avail. This is bit of a last resort "I don't know where else to look" sort of thing.***
the compass is item #4 1990-91 J,G bodies
have one but the button lettering is worn off
1 HOUSING, Console
AR59 JB9 1 Blue
AR59 JD5 1 Quartz
AR59 JR8 1 Red
AR59 JV8 1 Champagne
4521 502 1 BRACKET, Console Mtg.
4481 470 1 WIRING, Jumper
4620 116 1 BEZEL, Trim
2 4620 114 1 DOOR, GDO
3 4620 061 1 DOOR, Sunglass Bin
4 4437 490 1 MODULE, Compass/Temperature
5 4547 576 2 SPRING, Judco Switch
6 4309 336 1 DAMPER, Viscous
7 4547 578 1 SPRING, Sunglass Latch
4547 579 1 SPRING, Kick Out
8 4547 580-1 1 LENS, Reading Lamp
9 4547 577 2 BULB, Lamp
10 4547 573 1 HOUSING, Bulb
CONSOLE, OVERHEAD J BODY
Figure 8A-1800
MODEL
slave player is 4469386 same as 5269072 1990-92
you will need the cable to connect to the radio which has to be the Ultimate sound radio that has the plug in for the cable. It is possible the cassette radio may have the plug in also ...can't remember.
I have some of the CD players but they are untested.
5269 178 1 Am/Fm/Mx w/Cassette, Black
4469 320 1 Infinity Sound, w/Cassette
4469 204 1 Ultimate Sound
PACKAGE, Radio Knob
4713 802 1 Black
4713 803 1 Bright
4469 386 1 DISCPLAYER ***
4469 028 1 CABLE, Disc Player
20 2 SCREW (DNS)
21 MODULE
5269 270 1 Traveler
1 E.V.I.C. (5268013 Service Vendor)
22 BOX, Cubby
5265 088 1 Upper
5265 086 1 Lower
23 P598 JV8 1 COVER, Cluster Outer Trim
Hey Marty,
Could you private message me with a price for the compass/temp module, and the single disc slave CD player and cable?
Thanks! ~Dave
As a side note, there are CD/Cassette combo head units available that will fit your car if you can't find a working slave CD unit.
There's a LeBaron in the junkyard near here with the 6 button computer and digital dash. It probably has a lot of the same parts as your car. I haven't been to look at it yet. I might be able to swing by and check it out this weekend.
Hi Marty, I'm not sure if I have this right...do you have a six button EVIC with worn lettering? Because if you do, I sure want it. I noticed the numbers for yours are 52680113 "Service Vendor"?....and a 5269270 Traveller...which I thought was the two button one....anyway...I'm after a six button EVIC. The numbers on the back of mine are 5269234. I'm grasping at straws here Marty....hopefully you have one,
Cheers,
Rick C
If Marty doesn't have one, I probably have one in storage somewhere.
1 - 6 of 6 Posts
