So my work was delayed because I had a crazy week/weekend and we had a snowstorm roll through.
Looking up to #4
Before everything got busy I got the oil pan off (I am redoing the gasket) as well as I wanted to make sure everything looked ok down in the bottom end.
(After adjustment)
I noticed that the balance shaft chain was kinda loose around 1/2 inch of side to side slop. The guides have very little wear. There is only wear from the 2 sides not the center. I decided to tighten the tensioner up a little. Set it so that there is still some side to side play but a lot less. (Around 1/8 inch) is this an ok setting?
Other than the chain everything looked good.
When I pulled the pan an oil saturated foam(?) noodle came out of the transmission area. Is disintegrating when it tried to pick it up. What was it? Is it important?
